Browse Forums Windows & Doors 1 Sep 21, 2009 11:58 am My house fronts a busy street. My daughters bedroom faces the street with 2 double hung sash windows ( in a single unit) Recently, council installed a speed hump right outside my house resulting in a substantial increase in noise mainly from buses which accelerate sharply from the speed hump. For heritage reasons, I'd like to retain the look of the old timber window without alteration. What is the best approach to adding sound proofing to this situation? Can I add another window inside the existing window? I looked at magnetite but I'd prefer an proper opening and shutting glass window. Any suggestions and ideas of cost would be appreciated. Re: Sound proofing a double hung sash window 2Sep 21, 2009 12:59 pm Window panes generally have low acoustic insulation. They can be improved with lamination, increased thickness or double glazing. However, a large contribution to sound transmission is related to flanking transmission through gaps around the fenestration. Sliding windows (particularly double sash) windows are harder to seal than hinged windows. That is probably why this window is so troublesome. Have you tried adding some furred weatherseals. These are a cheap fix that may help. Anything after that becomes a little expensive. Re: Sound proofing a double hung sash window 4Sep 21, 2009 6:57 pm Kieranc What sort of cost would I be looking at for a second internal window? Over a grand a pop? This might be a stupid question, but which trade does that? Glazier? Carpenter? Builder? EcoClassic can quote this for you, please contact direct. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Sound proofing a double hung sash window 5Sep 21, 2009 8:47 pm Whilst good test data about thermal insulation accompanies many windows, there is less information for specific products on acoustic insulation. The important figure is the STC (sound transmission class). A rough rule is every 10 STC reduces perceived volume by half. However, sound attenuation varies across the frequency range and STC is not as informative for low frequencies and transportation noises. viewtopic.php?p=131328#p131328 We are set back about 60 m from a country road and have double glazing with well sealing casement windows. I think they help noticeably in reducing the noise but my wife is still bothered by hoons driving by. If you just crack the window slightly open, most of the effect is lost. Lastly, the installation can be as important as the window itself. Windows are generally installed by carpenters but repaired by glaziers. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20677 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16304 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7488 |
