Scratched Windows
Has anyone else had this and what did your builder do about it?
vid, do you mean on the glass or the surrounds? If it's bothering you maybe you should say something, but then again I think you also have to consider ''picking your battles''.
The scratches are on the glass itself, I think I will say something but I'm not quite sure when, I'm also not sure if I should clean all the windows so I can see if any others have scratches or if I do will the builder say I shouldn't have touched them.
Scratches are mostly caused by cleaning... so don't touch your windows as they can then blame you...
You should report it immediately, it's a fairly standard problem.
Here's a summary from the HIA which includes the standard.
Thanks for that info I think I will give our SS a call next week.
Makes it a pain for the owner come lock-up time to see inside the house but
you can peel it back and see inside.
Provides at least a little protection for the windows when there is so much dust
and dirt flying everywhere
hence many of the builders up this way using Goop! or similar paint on glass protector.
It's expensive... we (and others) use plastic film and adhesive tape on all glass surfaces.
Ed
no wonder they appear with scratches and dents when installed.
I always wondered why they do not at least glad wrap the windows
when they literally drop them off in the dirt. Wouldn't this be cheaper for them
than a builder ringing up requesting replacements.
would it be fair to say Ed that in many home estates with so much dust/dirt around
that as you say time cleaning comes it's the dirt that scratches the window?
When you see the way many of the window's are dumped on-site it's
Hi Ozzroo
Ours are all wrapped. Windows are mostly damaged during construction with render or mortar splashes and someone wipes the stuff off when it's wet or the cleaner tries to scrape it off later. The method always leaves a tell tale pattern.
It's important that the windows arrive on site when the house is ready, any earlier and they sit around and are, as you say, prone to damage.
Never use a blade on glass, never use any hard sharp edge on toughened glass... you are likely to scratch it. Toughened glass has a logo on the corner (all doors are toughened). Toughened glass has a surface covered in "fines" which can be picked up on a blade and it's the fines that scratch glass.
If you clean glass make sure the cloth is perfectly clean.
Ed
Seems, as usual, the HIA guideline is leaning heavily towards protecting the builder. 10mm long fracture or chip acceptable???
I wonder if the same stuff they use to repair chips in windscreens will reduce the appearance of scratches/chips in house glass?
Its not going to help you much now but i got all the windows covered in scratch protective goop. The whole house cost $150.
As mentioned before I haven't spoken to the SS yet so I shouldn't be a pessimist BUT if I have any problems with the builder replacing I guess I could also use something like the following, I shouldn't cross that bridge before I get to it though!
7
Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.…
30/06/2023
Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will…
18/09/2023
I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside…
