Browse Forums Windows & Doors 1 May 31, 2007 7:50 am After having our new house re-tiled, the floor level changed so I went to plane the bottom of the pocket doors (the sliding doors that go into the wall cavity).
I planed off right into the hollow core! The finished height of the door panel is now 2010. What is the solution? Do I fill the void with a block of timber so I can attach the nylon slides or is it new door time? Do they make doors that can be cut down to 2010, with 2040 being the standard size, I believe? Re: Trimming pocket doors 2May 31, 2007 8:51 am I would make a new bottom rail to fit firmly inside the veneer & tight up to the side rails.
Run several shallow grooves across the rail [vertical] so that there will be adhesive still on the rail when you slip it in. Use a good quality adhesive, clamp the lot up & leave the pressure on for several days until its completely cured. It's always better [in retrospect] to take some off both top & bottom but this is not always a solution if you need to shorten the door by a large amount. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. we have a standard size and often we have a lot of variety to choose 0 3577 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5044 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4355 |
