Browse Forums Windows & Doors 1 Aug 06, 2009 4:07 pm What options do I have for the external windows' mouldings? I'm aware of those styro cement coated thingys and obviosly the timber ones. Any other options ? My window frames protrude 2-5mm from the cladding, because timber studs aren't 100% straight. Which type of moulding would be the best to cover that and what method ?? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Which window mouldings ? 3Aug 12, 2009 11:31 am noidea please use Hebel by CSR Thanks NI. I've had a quote from Unitex, very expensive, asked for the same fr Hebel, still waiting. Wonder if timber's any good. My old shack has timber window mouldings.... Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Which window mouldings ? 4Aug 12, 2009 12:03 pm kristofw What options do I have for the external windows' mouldings? I'm aware of those styro cement coated thingys and obviosly the timber ones. Any other options ? My window frames protrude 2-5mm from the cladding, because timber studs aren't 100% straight. Which type of moulding would be the best to cover that and what method ?? Chris Cant you simply push the windows in a few mm then buzz the reveals from the inside before installing achitrave. Re: Which window mouldings ? 5Aug 12, 2009 12:16 pm borg Cant you simply push the windows in a few mm then buzz the reveals from the inside before installing achitrave. Would do no good. Problem is cladding surface being a few mm off one way or another, following the studs' edges. Aluminium frames come with trimmings that can hide that, or can be set deeper inside the openings as they're much thinner, not posible with PVC. Too late for that anyway, the windows're screwed in and fixed with expanding foam, moving them would be quite hard and costly. The best solution is to butt the external mouldings against the frames, then fix the imperfections with packing and render. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7589 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7310 |
