Browse Forums Windows & Doors 1 Jul 01, 2005 9:45 pm Hi
I am renovating a house for rental and the windows will not remain open. I am told that they are spring loaded windows not sash windows. Does anyone know how to adjust or repair these windows or a website that can help Have a great day and thanks in advance penton Re: Fixing Spring loaded Windows 2Jun 13, 2006 10:44 pm On the bottom of the sash there is a screw which attaches the bottom of the spring to the sash via a lug on the actual bottom of the spring. The spring is concelaed inside the plastic tube that runs down the frame on either side of the sash. You need to be careful undoing the screw as you will need to hold the little lug flat into its recess otherwise the spring will go berserk and can do some damage to fingers or the woodwork.
The manufacturers of the spiral balances make a special hook that you can fit into the screw hole so that you grab the lug and then turn it to tighten the spring - don't forget to hang on! Lay the lug back over into the recess on the bottom of the sash and put the screw back in. Not too difficult and should only take a few minutes for each spring. Re: 4Jul 18, 2010 8:18 am builda On the bottom of the sash there is a screw which attaches the bottom of the spring to the sash via a lug on the actual bottom of the spring. The spring is concelaed inside the plastic tube that runs down the frame on either side of the sash. You need to be careful undoing the screw as you will need to hold the little lug flat into its recess otherwise the spring will go berserk and can do some damage to fingers or the woodwork. The manufacturers of the spiral balances make a special hook that you can fit into the screw hole so that you grab the lug and then turn it to tighten the spring - don't forget to hang on! Lay the lug back over into the recess on the bottom of the sash and put the screw back in. Not too difficult and should only take a few minutes for each spring. Spot-on... but if you are not up for that (your balancers may need replacing), then Google window spiral balance replacement... Here's one, but not too close I think... but call anyway they may do your area, or know someone who does... http://mrsashcord.com.au/?gclid=CISPsbH ... bwodPRZAhg Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12747 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9567 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 |
