Browse Forums Windows & Doors Re: Bi Fold Door Problem (Revised post) pic attached 3May 16, 2007 11:11 am Thank you very much for your information.
The building company flat out refused to put in another bottom bi fold door. They now believe that a bottom mounted bi fold is not suitable for this opening. To try and resolve the problem we wanted a stacker door which would have gone straight into the opening but the building company was stubborn and refused to pay the additional couple of hundred dollars required. We are very concerned at the moment regarding what they propose to do Regards Michael Re: Bi Fold Door Problem (Revised post) pic attached 4May 16, 2007 12:50 pm Hi
Quote: The building company flat out refused to put in another bottom bi fold door. They now believe that a bottom mounted bi fold is not suitable for this opening. Quote: To try and resolve the problem we wanted a stacker door which would have gone straight into the opening but the building company was stubborn and refused to pay the additional couple of hundred dollars required. Quote: We are very concerned at the moment regarding what they propose to do Check the slab closely ... because a stacker door would also require an accurate slab and good support , and it is strange that the builder turned down this option when it is a cheap "out". Thanks "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Bi Fold Door Problem (Revised post) pic attached 5May 16, 2007 12:51 pm Hi
Quote: The building company flat out refused to put in another bottom bi fold door. They now believe that a bottom mounted bi fold is not suitable for this opening. Quote: To try and resolve the problem we wanted a stacker door which would have gone straight into the opening but the building company was stubborn and refused to pay the additional couple of hundred dollars required. Quote: We are very concerned at the moment regarding what they propose to do Check the slab closely ... because a stacker door would also require an accurate slab and good support , and it is strange that the builder turned down this option when it is a cheap "out". Thanks "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Bi Fold Door Problem (Revised post) pic attached 6May 19, 2007 6:47 pm Michael,
With 20 plus year experiance i have i would say the door has never been fitted right!!!!! The door you have needs to be EXACTLY level, with no dips or bows in the bottom track.The same with the top track. OPEN DOORS FULLY, get a tape measure ,then measure, one side, floor to top of door INTERNAL. do the same in the middle.These measurements should be exactly the same. The door needs to be solid fixed at the head track,as this takes ALL the weight!!!!!!!!!! The steel support you have above is fine to fix into,just very hard to do for the average builder!!!!!!!!!!!!!. Also it is important to measure the diagonals across the whole outerframe,This insures the frame is square. I fit doors upto 6.5 metres wide exactly like yours and they are double glazed, so imagine the weight of these!!!!!!!. All of my installations work fine. Get a proper installer to have a look, builders fit doors,ok,but bi- fold doors are a bit of a art to do. Reguards Ian Re: Bi Fold Door Problem (Revised post) pic attached 7May 19, 2007 9:28 pm Quote: The door needs to be solid fixed at the head track,as this takes ALL the weight!!!!!!!!!! The steel support you have above is fine to fix into,just very hard to do for the average builder!!!!!!!!!!!!!. Michael says it's a bottom hung door... so the slab is critical. And the builder's need to change to a top-hung does suggest either that there is a quality problem with the bottom hung door or the slab is out. Ed Re: Bi Fold Door Problem (Revised post) pic attached 9May 20, 2007 8:08 am michael,
Just to make sure of things, has your doors got sliding wheels at the bottom, if so its bottom hung. if not it is top hung. If this is the case then as required by the manufacturer the head section needs to be fixed. AS BY THE MANUFACTURER DID TELL YOU IS THAT RIGHT . let me know either way , not much gets pass me. Hope i can help reguards Ian Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3393 Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18430 |
