Browse Forums Windows & Doors 1 Jun 24, 2009 7:36 pm Building with PD - Regent 23 Cascades on Clyde Estate HomeOne Building Thread - PCI Completed - 28th August. Handover - 11th September. Re: Ebay Door - Advice PLEASE!! 4Jun 25, 2009 12:03 am kexkez check the width of your doorway and make sure it's the same. It looks like the plain version of the corithian door we put as our laundry door. The width/heigh is fine.. just the thickness I was unsure of. The rest of our doors are the plain or flush ones so it will match! =) borg usually internal doors are 35mm thick and external doors are 40mm thick. So yours should be the same. I just replace the door on its own ie dont change the frame. It can take a few hours maybe more depending on what type of lock you install. Just had a look at the actual door and it has a sticker on it that says 35mm.. however the frame looks as though it can hold a further 5mm. It actually looks crooked as it is, as the hinge is flush with the inside and the lock is flush with the outside, so it's kind of crooked by 5mm. Not sure how that will work with the lock or whatever.. but we'll sort something out. I'm sure i won't be too dissapointed if it doesn't fit if i've only spent $13. Building with PD - Regent 23 Cascades on Clyde Estate HomeOne Building Thread - PCI Completed - 28th August. Handover - 11th September. I personally think pivot door are over the top, as you said a bit impractical having a small useless section and poor insulation. Iām pretty happy with a 920x 2040 with… 1 383 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17939 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5808 |
