Browse Forums Windows & Doors 1 May 28, 2009 7:54 pm Hi I have a troublesome arch doorway -attached. The arch is in the middle of the room and I would like to move the door to the side of the room and square it off. Will I need an architect’s approval and planning approval for this? What if I just wanted to square the arch off in its current place, would this need the above tick of approval? The wall inside is the wall that forms the side of the house. Anyway I would very much appreciate any assistance. Smallman Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Moving a brick arch 2May 31, 2009 7:20 am The wall is load bearing. You will need engineering advice for both suggestions. An arch naturally bears the load where a square will need a steel lintel. Get some serious advice or hand over your job to a builder. But if you cut a new hole you can do that before you close the old one (provided you have spare bricks...). Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61375 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72337 2 8358 |
