Browse Forums Windows & Doors 1 May 20, 2009 3:32 pm Bifold doors? But they are hard/impossible to screen, not sure if that is a concern or not. Panelled doors, so you mightn't get the full 2m, but if you divided it into 4 or 5 panels, you would have 50cm or 40cm of panels at the end where all the doors were stacked when opened then the rest would be open space. Re: Sliding Doors Help ! 2May 20, 2009 6:30 pm I agree with C&D... if you already have an opening of 1.2m in 2m you must have a stacker door, so bifold is the way to go for a bigger opening. However as a pool table owner who has an 820mm door - there is not much that won't go through your existing door. The legs come off the pool table, and I don't know any couches that won't fit through 1.2m x 2.1m. If you get stuck, you could remove the opening panels from your stacker and get another 150mm. Your supplier could even remove the fixed panel at a push and you would have 2m. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Sliding Doors Help ! 4May 20, 2009 10:57 pm Macy Modular. Three pieces, possibly more. I agree - but if you are worried, buy it on the basis it will fit through your door. If it doesn't, you can return it and get your money back... but I would put money on it going through an 820mm door. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Sliding Doors Help ! 5May 21, 2009 12:16 pm C&D Bifold doors? But they are hard/impossible to screen, not sure if that is a concern or not. Panelled doors, so you mightn't get the full 2m, but if you divided it into 4 or 5 panels, you would have 50cm or 40cm of panels at the end where all the doors were stacked when opened then the rest would be open space. Not exactly true....I've seen bifolds that fold inside and an exact copy of the bifolds in a alluminium mesh on the ouside(so you would have 2 bifold doors on the opening like a mirror of each other one in glass one in the mesh). Expensive probably but hard/impossible i dont think so. Re: Sliding Doors Help ! 6May 21, 2009 2:59 pm D&SG C&D Bifold doors? But they are hard/impossible to screen, not sure if that is a concern or not. Panelled doors, so you mightn't get the full 2m, but if you divided it into 4 or 5 panels, you would have 50cm or 40cm of panels at the end where all the doors were stacked when opened then the rest would be open space. Not exactly true....I've seen bifolds that fold inside and an exact copy of the bifolds in a alluminium mesh on the ouside(so you would have 2 bifold doors on the opening like a mirror of each other one in glass one in the mesh). Expensive probably but hard/impossible i dont think so. There are many ways to screen a bifold door... all expensive and all unforgiving if you have animals or small children. Also unsuitable for windy conditions. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 we have a standard size and often we have a lot of variety to choose 0 3575 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5039 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4353 |
