Browse Forums Windows & Doors 1 May 04, 2009 12:34 pm Hi I am quite new to this forum. Please forgive my ignorance (if any). I am trying to build a double story house in Canberra. Ground floor is of height 2700 and first floor is of height 2500. I am planning to use 1.8 m windows thru out the house. Is it Ok. I am planning to go for DA in next week. Thanks in Advance chandoo007 Re: Windows Height for Raised cealing (2700) 2May 04, 2009 1:09 pm chandoo007 Hi I am quite new to this forum. Please forgive my ignorance (if any). I am trying to build a double story house in Canberra. Ground floor is of height 2700 and first floor is of height 2500. I am planning to use 1.8 m windows thru out the house. Is it Ok. I am planning to go for DA in next week. Thanks in Advance chandoo007 Personally I would use 2400 GF and 2100 1st F... If you are looking at the aesthetics, draw the facade to scale to judge. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Windows Height for Raised cealing (2700) 3May 04, 2009 1:18 pm When you say 1.8 m windows, this sounds like the window height, not the head height (=sill height + window height). I've got 2.7 m high ceilings throughout and I'm going for 2.4 m head heights. This is for windows and doors as well. The cheaper option is a 2.1 m head height, but then there is 600 mm betweent the top of windows/doors and the ceiling, which I think is a bit too much. Also, not only do higher windows look nicer, but they give you more opportnity to look up to the sky which is a nice feeling. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Windows Height for Raised cealing (2700) 4May 04, 2009 1:21 pm Casa2 When you say 1.8 m windows, this sounds like the window height, not the head height (=sill height + window height). I've got 2.7 m high ceilings throughout and I'm going for 2.4 m head heights. This is for windows and doors as well. The cheaper option is a 2.1 m head height, but then there is 600 mm betweent the top of windows/doors and the ceiling, which I think is a bit too much. Also, not only do higher windows look nicer, but they give you more opportnity to look up to the sky which is a nice feeling. I agree... and the modern option has been to have windows start at floor level. (Some energy efficiency reasons have forced windows away from the floor while builders try to avoid double glazing). Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Windows Height for Raised cealing (2700) 5May 04, 2009 3:18 pm Thank you very much for your info. is there a much cost between 1800 and a 2100 window height? Re: Windows Height for Raised cealing (2700) 6May 12, 2009 6:42 pm Casa2 When you say 1.8 m windows, this sounds like the window height, not the head height (=sill height + window height). I've got 2.7 m high ceilings throughout and I'm going for 2.4 m head heights. This is for windows and doors as well. The cheaper option is a 2.1 m head height, but then there is 600 mm betweent the top of windows/doors and the ceiling, which I think is a bit too much. Also, not only do higher windows look nicer, but they give you more opportnity to look up to the sky which is a nice feeling. Have you raised the window height for bedroom as well? or can we raise it.. not sure how it will look ok thanks - yes was wondering if that should have been listed as Option Three! 2 7742 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9564 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16009 |
