Browse Forums Windows & Doors 1 May 01, 2009 8:20 pm We do not want a security door covering our entry door. I was hoping to have a matching opening sidelight or highlight to allow airflow. I have googled a lot of door places and opening side/highlights don't appear to be something readily available. We are thinking of having the PMAD104 hinged 1200x2340 (opening is 1300). Any advice or other ideas? 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Re: Front door windows 2May 01, 2009 8:32 pm Anna1 We do not want a security door covering our entry door. I was hoping to have a matching opening sidelight or highlight to allow airflow. I have googled a lot of door places and opening side/highlights don't appear to be something readily available. We are thinking of having the PMAD104 hinged 1200x2340 (opening is 1300). Any advice or other ideas? Hi No idea what PMAD104 is. Best bet is to have a 3rd party window like a Breezeway louvre or Aneeta sashless double hung fitted into the sidelight space. But be prepared to pay over $1,000... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door windows 3May 01, 2009 8:39 pm Thanks Ed I know you wont be able to sleep PMAD104 attached http://www.corinthian.com.au/popups/productzoom.php?grp=ext&rnge=pmad&prod=PMAD104. I'm probably leaning toward an opening highlight, same cost do you think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Re: Front door windows 4May 01, 2009 9:53 pm That looks like the door we have got for our home. We went with frosted inserts for privacy & chose to have double doors. Nice choice Re: Front door windows 5May 01, 2009 10:51 pm Anna1 Thanks Ed I know you wont be able to sleep PMAD104 attached http://www.corinthian.com.au/popups/productzoom.php?grp=ext&rnge=pmad&prod=PMAD104. I'm probably leaning toward an opening highlight, same cost do you think? It will be lowest cost as a separate window above your entry, but how will you open it? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door windows 6May 01, 2009 10:58 pm Ed wouldn't that be like an old-fashioned transom (sp) ? My parents have a Victorian era home and they have transoms over their front door and french doors. They both open with a long brass rod thing that you push or pull to open / shut. Sorry if this is garbled - am off to bed now Some things are worth waiting for. Re: Front door windows 7May 02, 2009 12:30 am We are building a very modern home, can you get winders that come down the wall to a decent height? I'm just pushing the price up again aren't I! 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Re: Front door windows 8May 02, 2009 7:41 am you can get electric winders, but I think it will add maybe $600... There are mechanical ones too that use piano wire... also expensive. I would invest in a pair of steps. Hi Kyton. A transom is the horizontal bar on a window (the vertical bar is called a mullion). ED "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door windows 11May 02, 2009 10:22 am Steps it is - thanks for your help 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24800 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 |
