Browse Forums Windows & Doors 1 Apr 22, 2009 5:34 pm Hoping someone out there can advise, We are having an open corner between the alfresco and the living and dining area. To achieve this look we are using stacker doors which open away from each other. The engineering for this has been sorted and the house in in the initial stages of construction. Our builder is using dowell doors but has said that he has not used stacker doors in this situation where they will lock together at a 90 degree angle. Has anyone used dowell stackers in this situation? How did they lock together? What brand of door did you use? All comments appreciated! What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12407 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7919 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3599 |
