Browse Forums Windows & Doors 1 Apr 07, 2009 8:10 pm I want French doors out the back of my house. As cheap as possible! Could a builder use 4, one light doors from Bunnings? One each side to be rigid, the 2 in the middle as the French doors? I think all up would be about $720! Not positive it's possible, am open to ideas! Remember that not getting what you want is sometimes a wonderful stroke of luck! - Dalai Lama Re: Can this be done for a French door? 2Apr 07, 2009 8:21 pm I see no reason why this can’t be done! Anything can be done, as long as your builder is willing to it. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Can this be done for a French door? 3Apr 08, 2009 9:56 am You will also need a jamb and sill for this to work, the other problem you will have is where you hang the doors off the fixed doors (now sidelights) you have no way of sealing the gap in between without putting a rebated stile in there. Other problems i can for see is how do you plan on fixing the static doors (40mm) to you opening, you will have no reveal to fix architraves too. Just some food for thought. Regards Ben Re: Can this be done for a French door? 4Apr 08, 2009 10:14 am BUILDERSEDGE You will also need a jamb and sill for this to work, the other problem you will have is where you hang the doors off the fixed doors (now sidelights) you have no way of sealing the gap in between without putting a rebated stile in there. Other problems i can for see is how do you plan on fixing the static doors (40mm) to you opening, you will have no reveal to fix architraves too. Just some food for thought. Regards Ben There are suppliers who make only door frames (sorry I only know Vic suppliers), so get a quote for the frame to fit the doors - my guess $500. The gap can be finished with an off-the-shelf mushroom stop. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Can this be done for a French door? 5Apr 08, 2009 11:25 am ed @ EcoClassic BUILDERSEDGE You will also need a jamb and sill for this to work, the other problem you will have is where you hang the doors off the fixed doors (now sidelights) you have no way of sealing the gap in between without putting a rebated stile in there. Other problems i can for see is how do you plan on fixing the static doors (40mm) to you opening, you will have no reveal to fix architraves too. Just some food for thought. Regards Ben The gap can be finished with an off-the-shelf mushroom stop. Ed That would look as rough as guts Re: Can this be done for a French door? 6Apr 08, 2009 11:44 am Goodness, it's all so confusing! May be a good idea to speak to my builder!! Remember that not getting what you want is sometimes a wonderful stroke of luck! - Dalai Lama Re: Can this be done for a French door? 7Apr 08, 2009 12:34 pm BUILDERSEDGE ed @ EcoClassic BUILDERSEDGE You will also need a jamb and sill for this to work, the other problem you will have is where you hang the doors off the fixed doors (now sidelights) you have no way of sealing the gap in between without putting a rebated stile in there. Other problems i can for see is how do you plan on fixing the static doors (40mm) to you opening, you will have no reveal to fix architraves too. Just some food for thought. Regards Ben The gap can be finished with an off-the-shelf mushroom stop. Ed That would look as rough as guts Sorry, totally disagree - it's what they do on double entry doors as standard. What is your solution? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Can this be done for a French door? 8Apr 08, 2009 1:01 pm The gap can be finished with an off-the-shelf mushroom stop. Ed[/quote] That would look as rough as guts [/quote] Sorry, totally disagree - it's what they do on double entry doors as standard. What is your solution? Ed[/quote] On double entry doors they use a mushroom stop "T" shape which is alot stronger than a tacked on "D" molding and its not on the hinged side. Solution would be to buy a frame and fit the 4x one lites into it but i would still put a rebated stile on eash side, 1 to attach the hinges to and 2 so as you have something descent to attach the side light to. you can buy pre-fab stiles in kdhw and meranti all you need to do is cut to length take a small rebate out of the sill and head and screw together. I quite often fit new entry systems with "lose" sidelights, it would be identical to buying one from the manufacturer except you may save your self some dollars, but just not time. Thanks Ben Re: Can this be done for a French door? 9Apr 08, 2009 1:07 pm BUILDERSEDGE The gap can be finished with an off-the-shelf mushroom stop. Ed BUILDERSEDGE That would look as rough as guts ed @ ecoclassic Sorry, totally disagree - it's what they do on double entry doors as standard. What is your solution? Ed BUILDERSEDGE On double entry doors they use a mushroom stop "T" shape which is alot stronger than a tacked on "D" molding and its not on the hinged side. Ben That's what I said... mushroom stop, not D mould. Plus manufactured door frame. Just like the real thing.... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Can this be done for a French door? 10May 09, 2009 9:44 pm The finished article, very happy! They are not stained yet, but it looks and works great!!Yaaay! French doors!!!.jpg101_0264 (Medium).jpg Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Remember that not getting what you want is sometimes a wonderful stroke of luck! - Dalai Lama I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15284 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11648 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1290 |
