Also, any idea as to which is cheaper?
Built in robes : Sliding Vs hinged doors
Page 1 of 2
But I know alot of people here like the sliding robes/doors. I think if you dont mind the look of either, a sliding robe is more practical. It doesnt take up any room space, especially if you have smallish rooms. Sliding robes are more expensive than hinge ones, but I'm not too sure as to how much more expensive.
A disadvantage is that you have to slide the doors back and forth to get into each side whn you're putting stuff away. But generally I am a fan of sliding
Good point about furniture, Donuts - now that you mention it, we have a bookshelf in front of one door of the spare room BIR (the bookshelf is against the wall perpendicular to the robe), couldn't open the door if it was a hinged door. No problem accessing the corner of the robe - its just got rarely used items like suits, formal dresses etc.
Quote:
Our sliding robe doors are really noisy and I hate it.
That's interesting, have not heard that comment or ever had that problem.
Do you need CLR or something on your tracks?
We definately have had this conversation before
Seriously, sliders are the way to go under 'normal circumstances'....I thought I would like them as well
Mrs B
I find if I keep my tracks vacuumed they don't make a noise.
(and yes Mrs B I'm feeling the dejavu, we've definitely been here before
EDIT: I thought CLR was for baths and so forth to clean them up? The doors dont seem to need anything thing on them they slide fine.
Can't see what difference it would make whether floor was carpet or not, slab or not, as the doors slide inside the tracks, not directly onto the floor covering. Our old house had a floorboard base, this one has a slab, haven't noticed any difference.
Perhaps I am just getting deaf in my old age
PS: and I am a 'she'
sorry
this is why irc (or chat) is easier
It's a PITA to have to go from side to side to see what's in the cupboard... who can be bothered?
And you know men called "Helyn" ??
You so funny Helyn
Just wondering if people prefer sliding or hinged doors
Sliding door robes are usually about half the price of hinged door robes
sliding cupboards should give you a little more access to the cupboard space, doors generally dont go all the way to the wall and that space in the corners is a bit hard to get to
Sliding doors can go up to 2750mm high
another advantage of sliding is that you can place furniture or walls very close to them without worrying about being able to open the doors. I would not have been able to have a broom cupboard in my laundry if it wasn't sliding, as there wouldn't have been enough room for the doors to open.
Sliding doors are good for small rooms like laundrys, but you can only access one side at a time
* Hinges are easier to install than railings
* Easier to maintain – no railings for the door to fall off
Cons
* Needs space to swing through to open
* May be difficult to get the door perfectly square in the doorway
Sliding
* Require less space than a hinged door
* Pocket doors can be hidden, giving a clean aesthetic
Cons
* Rails can be hard to install
* Must have strong load-bearing structure above it to hang off
* Can slip off guard rail
4
920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people…
15/06/2023
We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors?
