Browse Forums Windows & Doors 1 Mar 23, 2009 10:22 pm We got a 1200mm-wide for the entrance door. We are deciding which door it will be suitable. Currently, we have two ideas....one is to have a 1200mm-wide door while another one is to have a 920mm-wide door with a 198mm-wide sidelight. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A 1200mm-wide door Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A 920mm-wide door with a 198mm-wide sidelight. Which one do you prefer? Please give us some comments. Thank you. Metricon Amira Re: Entrance door selection 5Mar 24, 2009 2:10 pm We chose to have two doors with no sidelights - we instead are having a highlight over the top of the doors. Can't stand people "peeping" in through sidelights!! Some things are worth waiting for. Re: Entrance door selection 7Mar 24, 2009 3:41 pm donuts I like one big one. I like a big one too!! We are talking about doors right?? 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Entrance door selection 8Mar 24, 2009 9:08 pm lisanne donuts I like one big one. I like a big one too!! We are talking about doors right?? YES!!! we are talking about doors I like the one big DOOOOOR aswell! Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Entrance door selection 10Mar 26, 2009 10:41 pm Jennysmith I think second option is good one as to have a 920mm-wide door with a 198mm-wide sidelight will give a better and different look Yes Jennysmith, that's awesome but unluckily, our builder doesn't offer the sidelight with the width of less than 330mm.....that's really sad!!!~~ Metricon Amira Re: Entrance door selection 13Mar 27, 2009 9:41 am oh wow! this is exactly what we're thinking .. our allowance is the door+sidelight .. but we're thinking of getting just the one 1200mm door .. spot on! --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Entrance door selection 16Mar 29, 2009 11:37 am kikin iTalk I asked PD to provide us with the 1200mm wide door as well as the sidelight if they could fit all on the house entry. Does it suit on your front door? What's the answer from PD? Well, any question I ask, PD seems to push the answer towards the tender appointment. So the answer is, no idea. Re: Entrance door selection 17Mar 29, 2009 2:59 pm iTalk kikin iTalk I asked PD to provide us with the 1200mm wide door as well as the sidelight if they could fit all on the house entry. Does it suit on your front door? What's the answer from PD? Well, any question I ask, PD seems to push the answer towards the tender appointment. So the answer is, no idea. I reckon your entry width would be the same as ours (dramana 27), prehaps you couldn't get a 1200mm-wide front door... Metricon Amira Re: Entrance door selection 18Mar 29, 2009 3:53 pm The porch width (which is the same as the entry) seems to be 1450mm, so if you have 1200mm door, then you need to add 100mm for the wooden frame (just a rough figure). You'll end up with 150mm left. I have no idea what to do with it If you go 920mm then you'll end up with 430mm space left. The 200mm sidelight can fit, but you'll have 230mm left It's a big problem, isn't it ? I think the first option sounds good if they use thick woodern frame to fill up the space. It's just 15cm after all. Re: Entrance door selection 19Mar 29, 2009 4:27 pm iTalk The porch width (which is the same as the entry) seems to be 1450mm, so if you have 1200mm door, then you need to add 100mm for the wooden frame (just a rough figure). You'll end up with 150mm left. I have no idea what to do with it If you go 920mm then you'll end up with 430mm space left. The 200mm sidelight can fit, but you'll have 230mm left It's a big problem, isn't it ? I think the first option sounds good if they use thick woodern frame to fill up the space. It's just 15cm after all. Yes u r right, iTalk!! However, it is not a money matter but PD's work!! I dun think PD will allow you to do such big different as they have so many restrictions (e.g. sidelight must be more than 300mm)... so bad~~ Metricon Amira Re: Entrance door selection 20Mar 29, 2009 4:50 pm Well if 300mm for the sidelight, then it shouldn't be that bad. 920mm Entrance Door + 300mm Sidelight = 1230mm Total Width... That leaves 220mm (22cm) for the wooden frame which should be fine !! Or you could go for one huge 1200mm door which which is not too bad after all The warning is on the sticker on the door too. Second the aluminium powdercoat 6 12639 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 4960 Hi there, we have classic cream gutters, fascia’s, roller door and undercover carport. We are are going to paint the roof a terracotta orange colour. After some… 0 1180 |
