Browse Forums Windows & Doors 1 Dec 23, 2008 8:26 pm Here's a stupid question ... living in a house with sliding windows for the first time (renting)...
... how the #^(!*@#(* do you get the !@()*#) flyscreens off to clean the sliding window????? As you can tell from the expletives I've just spent 20 minutes wrestling with the (!@*&!& things and am getting extremely frustrated!! They are stuck in a recess on the outside of the frame. No amount of sliding will make them fit out. I tried a gentle bend which turned out to be a bad idea. (!) No sign of any screws or fixtures to remove parts of the frame to get the damn thing out... I'll be damned if I have to remove the mesh from the frame, clean window, then re-install it, a bugger of a job. It's looking like we will have to spend Christmas lunch looking through a layer of mud . Help!!!! "Now, supposing a house to have a southern aspect, sunshine during winter will steal in under the verandah, but in summer, when the sun traverses a path right over our heads, the roof will afford an agreeable shade, will it not?" -- Socrates, ca. 400 BC Re: How to remove flyscreens from sliding windows 2Dec 23, 2008 8:37 pm It’s a pain!!!! You have to do it from the inside of the house, with a couple of mine I have to take the windows out. Start in one corner and work it out gently, I bent one of my screens in the same **&^%^$%$ frustration as you! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: How to remove flyscreens from sliding windows 3Dec 23, 2008 8:39 pm Generally you would take out the sliding window - push fully up & pull out the bottom.
Same thing with the fly screen plus you need to move it sideways to release from the frame. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: How to remove flyscreens from sliding windows 4Dec 23, 2008 9:44 pm ausdesign Generally you would take out the sliding window - push fully up & pull out the bottom. Same thing with the fly screen plus you need to move it sideways to release from the frame. Ah ha!! Thank you!! That also explains why the windows had apparently random bits hacked off with bare aluminium exposed... so they could be got out. Geepers creepers. Do I have to remove the carpet to vacuum it or dig up the grass to cut it? "Now, supposing a house to have a southern aspect, sunshine during winter will steal in under the verandah, but in summer, when the sun traverses a path right over our heads, the roof will afford an agreeable shade, will it not?" -- Socrates, ca. 400 BC Re: How to remove flyscreens from sliding windows 5Dec 24, 2008 8:16 am You don't need to remove the sash - the screen should lift out. Lift up and to the side with a slight bend to get one corner out. Then pull it out.
The screen should be almost the same size as the opening - or they just drop out. It may be fitted with springs inside the groove, so you will need to push hard enough to depress these. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7077 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5948 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11839 |
