Browse Forums Windows & Doors 1 Nov 28, 2008 9:34 pm Hi everyone, I'm a carpenter and is currently renovating my house. Since my door is not the standard size I would like to make my own door. I have seen doors that have like the top half with fancy metallic frames fitted in between two sheets of glass. I was just wondering if anyone knows what these metallic frames proper name is and where can I buy it from?
Thanks Any good architect or building designer will be able to tailor design a home to suit not just your block width but also the site aspect, orientation and your lifestyle. … 1 342 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9211 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7589 |
