Browse Forums Windows & Doors Re: Permanent window paint 2Nov 18, 2024 1:05 pm ![]() I checked the last post of this but there was no answer. Who knows who sells paint designed for permanently painting or priming window glass? Not tiny tubes of decorative paint. TIA How permanent or tough does it need to be? You don't need special paint if it's not going to be taking constant wear. Just regular acrylic house paint will work. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Permanent window paint 4Nov 19, 2024 6:59 pm ![]() Permanent, as I said. Permanent is different to tough. Wall paint is permanent but not particularly tough. You gave minimal information so you got a basic answer. Just about any paint sticks to glass Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Permanent window paint 5Nov 19, 2024 7:06 pm ![]() ![]() Permanent, as I said. Permanent is different to tough. Wall paint is permanent but not particularly tough. You gave minimal information so you got a basic answer. Just about any paint sticks to glass My question around permanence was more around if you still want the ability to be able to reverse the process if required. If you don't care then slightly sand the glass beforehand and the paint will really stick. If you want the option to remove it, then don't sand it. Just paint it with whatever paint you want. That way a razor blade and a bit of elbow grease will get you back to clear glass. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 We built in 2013 and painted internally with the Taubmans colour 'Stonebridge - New Housing'. We recently decided to repaint with the same colour - half way through the… 0 22332 For 5 - 10L, you've dwindled your savings by the time you've spent researching. 10 13795 DIY, Home Maintenance & Repair Blistering paint in your newly painted bathroom stinks! It's likely due to trapped moisture. Bathrooms are humid, and if moisture gets between the paint and the wall,… 1 10914 ![]() |
