Browse Forums Windows & Doors 1 Sep 06, 2024 11:26 am Fixed Window Frame is 3mm below Stone benchtop (Kitchen) Sliding Window frame is 20mm above stone benchtop (Pantry) Should I ask to add a stone layer to make a sill to avoid water staying on this fixed window frame as its 3mm down. I have sink with tap in both windows Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It may be a sill rebate so that your bottom bricks support the door frame. Check with builder thiugh 2 37804 It seems to me like there just trying to cash in. Because my bench was 3500mm long they told me I needed to purchase a second slab of caeser stone, which is… 4 23229 I've gone for pre-fab walls. I did it because I wanted to remove the idiot factor from the construction on site , control theft and reduce waste plus its supposed to be… 10 80675 |
