Browse Forums Windows & Doors 1 Jul 24, 2024 4:34 pm I installed a new window which was smaller than the existing so has to fill in around it and next to it. Do you think something like this is ok? Or should I not have timber at the bottom of the window? I assume I should have wider flashing that sticks out past the timber but over the bricks? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Sealing window 2Aug 02, 2024 11:30 pm Bigdog7676 I installed a new window which was smaller than the existing so has to fill in around it and next to it. Do you think something like this is ok? Or should I not have timber at the bottom of the window? I assume I should have wider flashing that sticks out past the timber but over the bricks? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any responses? Re: Sealing window 3Aug 03, 2024 5:53 am You came up with a new design of a window frame that has unknown adequacy. The easiest way is to use an extra jamb studs on one end (where you filled the remaining opening) next to your new window from top to bottom plate of wall and another stud/s under lintel for bearing. You need to use weatherproof boards for cladding and fill any gaps remaining. Re: Sealing window 4Aug 03, 2024 6:35 am Eng. B A You came up with a new design of a window frame that has unknown adequacy. The easiest way is to use an extra jamb studs on one end (where you filled the remaining opening) next to your new window from top to bottom plate of wall and another stud/s under lintel for bearing. You need to use weatherproof boards for cladding and fill any gaps remaining. Thanks for the reply. Just curious about what to do with the flashing at the bottom. Should it hang out over the bricks at the bottom or just tuck it in and totally seal the bottom under the window? Re: Sealing window 5Aug 03, 2024 5:48 pm Please see this article. https://www.jlconline.com/how-to/exteri ... er-homes_o Re: Sealing window 6Sep 06, 2024 5:21 pm Bigdog7676 Eng. B A You came up with a new design of a window frame that has unknown adequacy. The easiest way is to use an extra jamb studs on one end (where you filled the remaining opening) next to your new window from top to bottom plate of wall and another stud/s under lintel for bearing. You need to use weatherproof boards for cladding and fill any gaps remaining. Thanks for the reply. Just curious about what to do with the flashing at the bottom. Should it hang out over the bricks at the bottom or just tuck it in and totally seal the bottom under the window? Make sure that the weep holes are clear and free to drain which should be on the underside of the sill, provided that the window is the right way up, "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 13446 DIY, Home Maintenance & Repair It looks like they have used rigid sealant in the gap. You are supposed to use flexible sealants in filling this gap to allow for expansion and contraction movement… 1 14579 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 15184 |
