Browse Forums Windows & Doors 1 Nov 04, 2008 3:37 pm Anybody has any technical info on installing PVC windows in the 90mm timber stud walls ?? Waterproofing, sills, packing, sealing, expansion gaps, anything at all ? There's nothing on PVC in the books I've managed to find, only on aluminium and/or timber.
Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How to install PVC windows in framed walls ?? 2Nov 04, 2008 8:04 pm It's the same as aluminium & timber except PVC is even more critical. Take care that the window is installed square and that the sashes and doors open before you permanently fix them.
PM if you need more help. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: How to install PVC windows in framed walls ?? 3Nov 04, 2008 8:12 pm Oh - I forgot - we supply with KD reveals attached. Depends whose windows you use as to how the reveals can be attached. Send me a photo and I will see what can be done. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: How to install PVC windows in framed walls ?? 4Nov 04, 2008 10:15 pm Quote: It's the same as aluminium & timber except PVC is even more critical. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How to install PVC windows in framed walls ?? 5Nov 05, 2008 7:58 am kristofw Quote: It's the same as aluminium & timber except PVC is even more critical. Chris So the total depth of your construction, plaster to exterior cladding is 90mm? And your windows are 70mm? And you want the window exterior to finish where? Level with the cladding? What does your profile look like? Is the profile same throughout your window & door schedule? Not sure what you mean - what about a sill - it's integral with the window. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: How to install PVC windows in framed walls ?? 6Nov 05, 2008 1:23 pm Hi EcoClassic,
Quote: So the total depth of your construction, plaster to exterior cladding is 90mm? And your windows are 70mm? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've never seen PVC windows installed in a stud wall. If someone could post a good quality picture, it'd give me the idea how to do it. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How to install PVC windows in framed walls ?? 7Nov 05, 2008 5:50 pm kristofw Hi EcoClassic, Quote: So the total depth of your construction, plaster to exterior cladding is 90mm? And your windows are 70mm? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've never seen PVC windows installed in a stud wall. If someone could post a good quality picture, it'd give me the idea how to do it. Chris Hi Chris, Sorry no pic with me. We would fit a perimeter reveal to attach the window to the house frame. how the reveal is attached to the window depends on your window design. It looks like your window has an inward opening sash with the drainage to the left or outside. If you give me a call I will talk you through it. I will PM you my contact details. Thanks "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7331 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4873 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 869 |
