Browse Forums Windows & Doors 1 Nov 01, 2008 11:10 am This is posted elsewhere in the forum... thought it may be better here.
Hi all What's watt - where do they go? Windows may as well be plugged into your power point going by the amount of watts they use. In energy terms, compared to bricks and mortar, windows are just holes in the wall which allow heat to move via conduction from the hot side to the cold side. The amount of heat they allow through can be predicted in a measure called window U value (or U factor). The U value of a window measures energy loss in watts per square metre per degree Celsius passing through the window, which of course shows up in your power or gas bill just like the watts of your electric kettle or iron! If a house was perfectly insulated it would require zero heating or cooling to maintain temperature equilibrium, so what we pay for in gas and electricity for heating and cooling is directly related to how much energy leaks into or out of our homes. The better a home is insulated, the less energy we need to keep our home at a comfortable temperature. Windows play the biggest part in the cost of that energy, like a leaky boat whose hull is watertight apart from a few holes - we must bail the water at a rate that is equal to the rate of the leak or the boat will sink; so too with windows and doors, we must replenish the heat gain or loss from our windows by turning on the heating or cooling to remain comfortable. Since a window’s U value is a measure of the window’s ability to conduct heat, then the lower the U value the higher its insulation or heat stopping properties. For U value, lowest is best. If we compare two windows, one with a U value of 3 and one with a U value of 2.7, then the window with the U value of 2.7 stops 10% more heat from being conducted through the whole window and requires 10% less energy to maintain the comfort level compared to the window with the U value of 3, that is 10% less in your heating or cooling bill for that window (looking only at windows in relation to energy). Everyone knows that generally double glazing is a better insulator than single glazing. But how much better depends upon design and the type of glazing. Poorly designed double glazed windows can perform worse than well designed single glazed windows where energy is concerned and double glazed windows vary enormously in energy terms. Heating & cooling can be half your energy bill. On a cold (or Hot!!) day, poorly designed single glazed windows (U value say 5 or more) can draw around 6 kilowatts per hour of energy to maintain comfort for an average 2 storey home. Choose windows wisely!! Windows are plugged in and switched on 24 hours a day - not like the dishwasher, and you can't switch them off!!. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27364 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9602 The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4246 |
