Browse Forums Windows & Doors Re: Is this a defect in my window frame? 5Jul 13, 2023 3:32 pm MsMish Hi all, I took these photos when visiting my new townhouse recently and noticed that along the bottom of these window frames it looks uneven/wavy, with excessive material and there’s even a small gap (see close up). Apologies for not knowing the proper terms to describe the issue but I hope the photos show what I mean. My pre-settlement inspection is coming up, should I raise this issue as a defect? Any thoughts are appreciated Close upLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Testing reply. Re: Is this a defect in my window frame? 6Jul 14, 2023 1:54 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I tried the same jpg and it would not show. I tried a second one and it didn't show either. So I tried this old one of mine... Must be something wrong with the files, yet they insert fine into Word. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Is this a defect in my window frame? 7Jul 14, 2023 2:05 pm Apologies to all for hijacking this thread. Ed, can you please email across the files to myself so may investigate. Cheers. DIY, Home Maintenance & Repair The intent of that sort of clause is being misaaplied. its suposed to be used to avoid paying out for things liek when you decided to do a reno yourself and the… 3 13830 It sounds like you’ve done some thorough troubleshooting! If the water isn’t passing through the valve even with the filter removed, it’s likely that the aquastop… 2 8226 |
