Browse Forums Windows & Doors 1 Jan 20, 2023 8:47 am While opening the window, I noticed the right side of the aluminium window can be partially pushed out (but not the whole way out). I can’t see any screws fixing it to the frame. After advice to fix it back to the frame please please. Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Window can be partially pushed out 2Jan 20, 2023 9:30 am cant really see whats going on there, but can sort of understand from your description. Is the other side fixed? if so you should be able to se ethe fixing. You could use the same and do it yourself, though I'd be more inclined to raise it with the builder to fix Re: Window can be partially pushed out 3Jan 20, 2023 11:34 am ![]() cant really see whats going on there, but can sort of understand from your description. Is the other side fixed? if so you should be able to se ethe fixing. You could use the same and do it yourself, though I'd be more inclined to raise it with the builder to fix Thanks for the response and suggestion. The other side isn’t fixed. It’s comes out as well (you can see the dirt markings as to how far the window can be pushed out in the pic below). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi El Forgo From what you are describing, I would be budgeting at least $6,000-7,000/sqm at an absolute minimum, possibly even $8,000. This factors in: 1. The sheer… 4 13863 ![]() From having seen numerous end-results and looked into the costs, I'm aware that having your 4-car garage completely underground in a basement is ... problematic. It seems… 0 11769 Can anyone help me out with this? I'm looking to renovate my house and came across these two designers on Fiverr ( if anyone knows this platform ) these… 0 6779 |
