Browse Forums Windows & Doors 1 Nov 27, 2022 2:57 pm I have a number of windows and doors that I want to flash between the frames and sarking for a brick veneer home. I’m at frame stage. Usually I’m used to the window manufacturer providing some flashing to the timber reveals then I tape that onto the sarking, however these windows are commercial grade (aluminium), and they have come without flashing. Any recommendations on what to do? I have about 150 lineal meters of window frames (top/sides) to flash. I could buy some butyl tape, but this gets expensive when need 150m. Are there other options? Re: Flashing windows 2Nov 28, 2022 10:20 am I assume your windows don't have reveals? If the sarking still has the window & door opening covered, you can cut the openings leaving flaps to seal it against the window.jambs Alternatively you need to use DPC membrane taped to both the window jamb and the sarking.. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 11087 I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10705 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6300 |
