Browse Forums Windows & Doors 1 Mar 03, 2022 9:07 pm Hi, Is it normal for aluminium frame windows to be warped like this over time? The window appears to open and close ok. Is this a sign of other potential issues? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Above: Warped at the base Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Above: Warped along the top of the frame. Any advice would be appreciated Re: Aluminium window frames not straight/warped? 2Mar 04, 2022 7:09 am Have you got any cracking around the house? Could be the house moving causing slab heave and putting pressure on the frames. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Aluminium window frames not straight/warped? 3Mar 04, 2022 7:48 am Noname Have you got any cracking around the house? Could be the house moving causing slab heave and putting pressure on the frames. There is cracking around the house. The house is on stumps not a concrete slab. Re: Aluminium window frames not straight/warped? 4Mar 04, 2022 8:03 am Renovate1 Noname Have you got any cracking around the house? Could be the house moving causing slab heave and putting pressure on the frames. There is cracking around the house. The house is on stumps not a concrete slab. House can still move on stumps. The cracking is evidence of the movement. How bad is the cracking? Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Aluminium window frames not straight/warped? 5Mar 04, 2022 8:18 am The cracking is in front porch area, driveway, some cracks internally on plasterboard. All the windows sills look slightly uneven. All the windows seem to have this sagging appearance on the top and bottom of the window frames. Re: Aluminium window frames not straight/warped? 6Mar 04, 2022 8:22 am Renovate1 The cracking is in front porch area, driveway, some cracks internally on plasterboard. All the windows sills look slightly uneven. All the windows seem to have this sagging appearance on the top and bottom of the window frames. Sounds pretty severe. I'd get a structural engineer to take a look. There may be some remediation that an be done. Hope you didn't buy it for a quick flip/investment. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Aluminium window frames not straight/warped? 7Mar 04, 2022 10:03 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ These windows look like a knife and fork job. I would think about replacement. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Aluminium window frames not straight/warped? 10Mar 04, 2022 12:05 pm Renovate1 These are the original windows from the 1960s apparently. The gaps are very evident. Then there is the lintel which looks to have a lot of surface rust. The lintel looks OK structurally, but the window is a mess. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10121 It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2292 |
