Browse Forums Windows & Doors 1 Jan 18, 2022 9:03 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
I recently replace our old four panel french door aliuminum frame with normal glass, to Stacker Aliuminum Frame Sliding Door (three panel) with 10.36mm laminated glass. But after installed, there are popping noise when there is directly sun heat. the supplier came two time to fix, but can't fix it. is this a contruction defects? Any one know how to fix? Re: Stacker Aliuminum Sliding Door Popping Noise 3Feb 08, 2022 9:44 am AWS 1meter long x 2 meter high each panel, three panel, one fixed panel, two sliding panel. popping noise happen when there is a temperature difference between indoor and outdoor, or when there is a direct sunlight. Re: Stacker Aliuminum Sliding Door Popping Noise 4Feb 08, 2022 10:09 am dc279 AWS 1meter long x 2 meter high each panel, three panel, one fixed panel, two sliding panel. popping noise happen when there is a temperature difference between indoor and outdoor, or when there is a direct sunlight. I have no idea. If it moves freely then I would guess the problem is in the installation where perhaps something is binding when it is expanding. If you didn't order a musical door , and the supplier cannot fix it, I would expect it to be replaced. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Ain't that the truth! We used to have a tile roof and had it replaced with colorbond and suddenly everything throughout the entire house sounds louder! 4 6698 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7904 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16155 |
