Browse Forums Windows & Doors 1 Sep 30, 2021 7:27 am Hi, House is about 2 years old and one of the double glazed windows now has condensation between the 2 pieces of glass. The builder said he believes that particular double glazed unit has failed and should be covered under the glass manufacturers warranty, The window supplier said the warranty is void as the rubber sill under the window has been removed. The rubber sill that usually sits on the brickwork has been removed as the building is rendered and sealed (sikaflex) between the window frame and the render. Any thoughts? I would have thought that the double glazed panel would not be affected whether the rubber sill was there or not. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: condensation inside double glazed panel 2Sep 30, 2021 9:45 am Installed incorrectly or not as the manufacturers recommendations is the builders fault...now they are all Passing the buck This also now raises the question concerning flashing, house wrapping and vapour barriers around the rest of the house? Most people check their drawings, details, engineering and post (photos) during construction, unfortunately, you have left it a bit late? OT, there's a shortage of qualified trades, materials, proper supervision etc...even more reason to start a thread, check your build during construction, ask questions and keep better records. As nobody remembers what was done 6 months ago on site, let alone 6 years on when your structural warranty has expired Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: condensation inside double glazed panel 3Oct 01, 2021 4:53 pm PeteG Hi, House is about 2 years old and one of the double glazed windows now has condensation between the 2 pieces of glass. The builder said he believes that particular double glazed unit has failed and should be covered under the glass manufacturers warranty, The window supplier said the warranty is void as the rubber sill under the window has been removed. The rubber sill that usually sits on the brickwork has been removed as the building is rendered and sealed (sikaflex) between the window frame and the render. Any thoughts? I would have thought that the double glazed panel would not be affected whether the rubber sill was there or not. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your window supplier is correct, and so is StructuralBIMGuy. Sealing the weep holes in the sill is a major problem and a direct cause of your condensation issue, your builder will already know this. he reason your sealed DGU failed is that there will be standing water which can't drain away in the glazing pocket and this eventually defeats the seal. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 12169 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 12815 id suggest getting an engineer to give you an opinion rather than a builder. 1 11928 |
