Browse Forums Windows & Doors 1 Jul 18, 2021 12:17 pm My front door is jamming up and isn't very noise friendly. Did they have different standard door sizes back in the day? It measures 2020x817. Seems from what I can see on the internet standard front doors these days are 2040x820 Obviously a 2040 door isn't going to fit. Re: Old house (1940's) front door non standard 2Jul 18, 2021 12:49 pm There would be enough tolerance in 2040x820 to customise to fit your opening. Before 1966 Australia did not have millimeters and we used the Imperial system invented in England, so a 2040x820 door would not be any standard. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Old house (1940's) front door non standard 4Jul 18, 2021 2:20 pm You always fit doors to the frame anyway so a standard 2040x820 will be fine. Modern frames allow for weather strips, often older frames you need to reduce the door height to install the weather strip. You will be able to remove 20mm from the bottom but I'd probably take 10mm from the top and bottom. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5480 Thanks. There are plenty of builders around my suburb. I'll make sure to do some door-to-door knocking, or note their building details on the temp fence. 4 4752 Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10216 |
