Browse Forums Windows & Doors 1 Jul 14, 2021 2:26 pm Dear folk I have got TREND brand sliding aluminum window. I was able to remove 20 out of 22 to clean their tracks but I failed with 2 I can lift them by a few mm but they still won't clear the bottom lip from their frame track,,,,,,,,dimension for those 2 sliding windows are 90mm by 120mm roughly. I checked if there anti-lift mechanism or top roller installed that can be wound down Any further trips can you please advise ? Thx Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any trick how to undo them from the frame ? Thx Re: Removing TREND brand sliding aluminum window to clean tr 2Jul 15, 2021 10:42 am Are the rollers adjustable from the side? Is there any sign of a bow at the head or sill which is shortening the frame height? If so, this would likely be an installation issue. Otherwise, you should call Trend as it does not make sense. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 3 51717 Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 11630 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 6152 |
