Building ForumWindows & Doors
Removing TREND brand sliding aluminum window to clean track
Dear folk
I have got TREND brand sliding aluminum window.
I was able to remove 20 out of 22 to clean their tracks but I failed with 2
I can lift them by a few mm but they still won't clear the bottom lip from their frame track,,,,,,,,dimension for those 2 sliding windows are 90mm by 120mm roughly.
I checked if there anti-lift mechanism or top roller installed that can be wound down
Any further trips can you please advise ?
Thx
Any trick how to undo them from the frame ?
Thx
Are the rollers adjustable from the side?
Is there any sign of a bow at the head or sill which is shortening the frame height? If so, this would likely be an installation issue.
Otherwise, you should call Trend as it does not make sense.
3
Build experience - Trend Connection Homes
How has your experience been like so far?
24/03/2024
3
Building Near Train Track - Additional Cost for Acoustics
Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too...
24/09/2023
4
Most affordable paint brand
General Discussion
Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent.
