We also have a problem with the window seal shrinking away from the corners of the same windows. If anyone has advice about what caulking we should use or if there's another solution?
Gaps in Aluminium Window/Door frames
Would you say both jobs are simple enough to do ourselves? We haven’t been able to find anyone to help us out with it yet.
Simple yes, but messy if you have never done it before. There are trades that can do this for you - try Facebook marketplace. Use the same silicone to cover the aluminium gaps, or buy some builders' bog in Bunnies
Thanks for your help!
I would recommend to have the rubber seals removed and caulked with a UV stable silicone, as the rubbers shrinking and pulling away at the corners will be caused by exposure to the sun. We do plenty of this and were just actually doing one today, feel free to head over to our website at https://www.correctcaulking.com.au/Caulking-Melbourne/ and send us an email if you would like some more advice.
Thanks,
Jono-Correct Caulking
Hi,
Thanks,
Thanks,
The biggest reason for the seals pulling away from the corners is the fabricator stretching the seal during assembly.
Ed
6
For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber…
12/01/2024
5
Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much…
