Hi Guys, I brought some windows form China for my new house. I am very happy with the quality and the dealing. However Some of those windows need to be glazed on size and installed, I am wondering if anyone have used or recommend a glaziers and installers who service Southwest
Thanks
Window Glazing and installation
Thanks
You have a problem.
- Are the windows compliant? An inspector may not give you a C of O, if you can't prove compliance to AS2047 and AS1288.
- Is the glass compliant? If the windows are not compliant to AS2047, then likely they are not compliant to AS1288.
- How do these windows install? Reveal? Brick anchors? This is to do with design of the windows (Australia is primarily brick veneer construction which is virtually unknown in China), the cost of the work involved and experience of the installer.
- Glazing, did the glass come with the windows? Glaziers like to supply and install - but any glazier can glaze your windows.
Good luck!!!
6
For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber…
24/10/2023
3
do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards
16/01/2024
13
This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well…
