Browse Forums Windows & Doors 1 Aug 22, 2020 11:20 am Hi, We are building new home in Brisbane. We have to do small change in pantry entry to add hinged door which we forgot in design stage. I have attached photos of current situation as we do not have door & door header. Opening space is 670-675mm. We want to add 620mm hinged door. We have trims, cornice & door jams left over from the work. We asked Builder to buy door ($75) & make header from 2x4 then add plaster sheet & finish for painter. I think it is easy job for Buider. Builder quoted $1275 for this. I feel it is random number they took from lucky dip lotto. What do you think? Whats should be the quote ranged? Regards, Chetan Re: Pantry Door Installation 3Aug 22, 2020 5:15 pm Sometimes I think people tradespeople quote excessively for a job that they don't want to do! And if someone is desperate enough to accept the quote, then it at least makes it worthwhile for them to do? Re: Pantry Door Installation 4Aug 22, 2020 8:13 pm chetansoni_3141 Hi, We are building new home in Brisbane. We have to do small change in pantry entry to add hinged door which we forgot in design stage. I have attached photos of current situation as we do not have door & door header. Opening space is 670-675mm. We want to add 620mm hinged door. We have trims, cornice & door jams left over from the work. We asked Builder to buy door ($75) & make header from 2x4 then add plaster sheet & finish for painter. I think it is easy job for Buider. Builder quoted $1275 for this. I feel it is random number they took from lucky dip lotto. What do you think? Whats should be the quote ranged? Regards, Chetan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pantry Door Installation 5Aug 22, 2020 8:20 pm Sparkyf Sometimes I think people tradespeople quote excessively for a job that they don't want to do! And if someone is desperate enough to accept the quote, then it at least makes it worthwhile for them to do? I agree with you. thanks for for reply.. Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5203 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44072 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5192 |
