Browse Forums Windows & Doors Re: Double glazing worth the $$ in Perth? 22Dec 20, 2019 1:55 pm Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Double glazing worth the $$ in Perth? 27Jan 15, 2020 12:27 pm Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Double glazing worth the $$ in Perth? 35Oct 14, 2020 10:27 pm Nannynap Just an update, I went with one of the cheaper suppliers recommended above and it has been a real nightmare. They start with an A, end with an O. Problems with the window units themselves, problems with the installation, and they are super super slow. They have said things on multiple occasions, and never actually do them. Talk is cheap I guess. I honestly couldn't recommend them on any level. So based on experience, for Perth specifically, I would be recommending waiting until glazing industry improves itself through increased competition as building codes get more green in the coming years. Only my point of view I know, I am some others must have had good experiences with them. But I do wonder how many customers effectively get paid to keep their silence, meaning I am not sure you can trust things like google reviews etc... they seem very cherry picked. I have received a quote from Michelle at Arco to put in 4 DG uPVC framed windows in our South facing side of the house (adjacent to an arterial route that can get noisy). Came in at $7400 for approx 9.5m2. They are very busy, cannot install until Dec/Jan. Was your experience with them not very good? Re: Double glazing worth the $$ in Perth? 36Mar 28, 2021 4:17 am just a novice but we recently had our bathroom reno'd and opted to replace the window to a new uPVC double glazed unit. For context, the house was built in the late 90's and had cheap crappy aliminium single pane glass. I was keen to see how much difference it made, so I borrowed an infra-red camera from work (high quality FLIR unit) and used it on one of the 40 degree days in Feb. The new DG window was 35.6 degrees, while one of the old windows in the next room (same external wall) was 39.1 degrees. We've upgrade the insulation, air-con and have added solar, so keen to replace a few more of the windows. Re: Double glazing worth the $$ in Perth? 37Mar 28, 2021 3:51 pm suburbanurbanexplorer just a novice but we recently had our bathroom reno'd and opted to replace the window to a new uPVC double glazed unit. For context, the house was built in the late 90's and had cheap crappy aliminium single pane glass. I was keen to see how much difference it made, so I borrowed an infra-red camera from work (high quality FLIR unit) and used it on one of the 40 degree days in Feb. The new DG window was 35.6 degrees, while one of the old windows in the next room (same external wall) was 39.1 degrees. We've upgrade the insulation, air-con and have added solar, so keen to replace a few more of the windows. Was that window getting some direct sunlight, or covered fully by eaves? Re: Double glazing worth the $$ in Perth? 38Mar 28, 2021 4:00 pm Nannynap Was that window getting some direct sunlight, or covered fully by eaves? There are eaves, Re: Double glazing worth the $$ in Perth? 39Mar 28, 2021 9:11 pm suburbanurbanexplorer just a novice but we recently had our bathroom reno'd and opted to replace the window to a new uPVC double glazed unit. For context, the house was built in the late 90's and had cheap crappy aliminium single pane glass. I was keen to see how much difference it made, so I borrowed an infra-red camera from work (high quality FLIR unit) and used it on one of the 40 degree days in Feb. The new DG window was 35.6 degrees, while one of the old windows in the next room (same external wall) was 39.1 degrees. We've upgrade the insulation, air-con and have added solar, so keen to replace a few more of the windows. You do realize this is not a scientific way of measuring the performance of a window in a particular climate zone? And even further from evaluating if it's worth the money. For isntance, we don't have 40℃ 24 hours- 365 days. Also, you are comparing one of the worse with one of the best, there is a lot in between. Re: Double glazing worth the $$ in Perth? 40Mar 28, 2021 11:00 pm perth97 suburbanurbanexplorer just a novice but we recently had our bathroom reno'd and opted to replace the window to a new uPVC double glazed unit. For context, the house was built in the late 90's and had cheap crappy aliminium single pane glass. I was keen to see how much difference it made, so I borrowed an infra-red camera from work (high quality FLIR unit) and used it on one of the 40 degree days in Feb. The new DG window was 35.6 degrees, while one of the old windows in the next room (same external wall) was 39.1 degrees. We've upgrade the insulation, air-con and have added solar, so keen to replace a few more of the windows. You do realize this is not a scientific way of measuring the performance of a window in a particular climate zone? And even further from evaluating if it's worth the money. For isntance, we don't have 40℃ 24 hours- 365 days. Also, you are comparing one of the worse with one of the best, there is a lot in between. Of course I realise its not a particularly scientific way of measuring the performance of a window hence the word novice being the THIRD word in my post and never suggested otherwise. I disagree with your reasoning about not having 40 degree days 24x7 - they are exactly the days im trying to make more comfortable. This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19806 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10406 |
