Browse Forums Windows & Doors 1 Aug 13, 2013 9:57 pm Hi all We are looking in to the cost of double glazing, smart glass etc. What is everyone choosing and what made you choose it? Re: Low E glass - are you using it, pros and cons 2Aug 14, 2013 9:31 am If you are in NSW, BASIX will have the biggest influence over which type of glass you will have to use especially for your N, E & W windows ( depending on your existing and proposed shade treatments for those windows too ). Low-e glass and an improved aluminium frame would probably be the most common window combo these days. You may get more replies if you post this question in the Window & Doors section. viewforum.php?f=23 Stewie Re: Low E glass - are you using it, pros and cons 3Aug 16, 2013 8:52 pm Thank you! I didn't even realise there was a dedicated area. Thanks for your reply 0 2439 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 18075 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 14653 |
