Browse Forums Paving & Concreting Re: Concrete around newly constructed house 5Jun 18, 2020 7:53 pm huubang JJ2019 huubang 1) Up to you I think. I like to use coloured concrete as it looks good. If you have money, you can do stenciling too 2) I would recommend at least 1m so that you have enough room to walk and move things around. At a minimum, as per standard, it has to be 0.9m width and 100mm thick and slope away from slab 3) I've just done 10m x 1m x 0.1m for 2200$. I was quoted 6500$ earlier to do 3 sides of the house (21m on sides and 10m at the back) 4) Make sure the concrete is at least 75mm away from weep holes. Very important! Concretor knows it but often tries to get away from it Thanks huubang for the information. I got a quote from one of the concreter's saying coloured concrete can be done at $60 per square meter. Not sure if my calculation is right. Wouldn't it be 10x60 in your case? For me the concrete around the house is more for protecting the slab than to walk. So trying to reduce the concrete done so that I won't loose much backyard. Your calculation is correct. However I can't find anyone who wants to do 60$ per sqm in South West Sydney (where are you located?). I guess it has something to do with the size as well. If you have a bigger job, you get the cheaper price. Wow!! it seems to be costly in NSW. I am in Victoria. Re: Concrete around newly constructed house 6Jun 18, 2020 9:02 pm It is also best to incorporate a spoon drain on the side of the path, particularly if you are on reactive soil. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15773 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8454 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7020 |
