Browse Forums Paving & Concreting Re: Lay concrete over concrete 3Nov 06, 2019 7:19 pm https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Lay concrete over concrete 4Nov 07, 2019 6:54 am Just an update...I purchased a bag of Ardex 46 for about $85. A little expensive I thought for 1 bag but it did the whole lot and managed to get about a 3 to 4mm spread across the top of it - dries really quick so only could mix a little at a time. Looks a whole lot better and so far so good. Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6255 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9196 |
