Browse Forums Paving & Concreting Re: Sealing Concrete Pathway 2Jul 14, 2019 2:01 pm It would probably look nicer for longer. Less likely to stain etc. I would say if you DIY it then go ahead. Its probably not worth paying someone to seal plain concrete. Other types of concrete it's a nice way to enhance the colour and give it the wet look. Just make sure there is no dust/dirt/moisture under the sealer. Driveways and Exposed Aggregate Specialists, Melbourne's Eastern and Northern Suburbs http://www.theconcretefirm.com.au http://www.exposedaggregate.net.au Re: Sealing Concrete Pathway 3Jul 14, 2019 2:03 pm Also a concrete warehouse type place. The sealer will likely be less than half the price of burnings. Allcon Concreters warehouse Parchem Midway building supplies. To name a few. Driveways and Exposed Aggregate Specialists, Melbourne's Eastern and Northern Suburbs http://www.theconcretefirm.com.au http://www.exposedaggregate.net.au Re: Sealing Concrete Pathway 5Oct 12, 2019 9:41 pm It's not necessary, but if you are concerned about aesthetics, then go ahead. There are more benefits which I am basing off on this article (right under the should I seal section near the conclusion): improving durability, minimising fading that often results from UV exposure, and controlling growth of mildew and mould. A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 6682 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6684 |
