Browse Forums Paving & Concreting 1 May 28, 2019 8:45 pm We are polishing our concrete slab, (semi exposed) However I want to protect the floors whilst the chippies put the frames up, so I purchased 4mm ply to lay underfoot, however Iām concerned about staining from the timber due to it being exposed to the elements Can anyone help? you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3667 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8071 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 |
