Browse Forums Paving & Concreting 1 Apr 01, 2019 1:30 pm Hi guys & gals, Installing a 1mtr concrete apron around our QLD home to provide a path and provide a water barrier and correct the fall in some areas. I have spoken with the termite company that installed and inspects our home and they will be providing a secondary treatment (some form of tape and nails) as the concrete path will not be lower than 75mm below the weep hole due to the need to follow existing concrete pads. I've searched the Internet, can anybody tell me if there is a minimum or best practice height between concrete path (under eaves) and weep holes. Obviously, the weep holes won't be covered, I've seen many paths around work with 10mm distances. Just unsure. Also, would you recommend expansion joins with a trowel or concrete cuts on exposed aggregate pathways? Thank you You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11170 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7084 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5436 |
