Hi
this is a picture of my back yard slab that shows where the coating
is failing, at the top you can see where a repair has failed.
This failure started to fail after two years, it is now 7 yrs old
I am looking for an expert tradesman in the Sydney, preferably south,
who can remove and replace the coating with one that will not fail.
If you know the contact details and if possible a website of someone who can do the job
I would appreciate it.
Thanks and Regards
Daniel
Hi Daniel, there are some applicators in Sydney that use our products.Its a concrete resurfacing material that is suitable for outdoor applications. Any good applicator would first ascertain the cause of the failure e.g moisture test. And apply a suitable solution e.g. moisture barrier. Also all the proper preparation must be done prior to applying anything. Like grinding the concrete surface to clean and promote adhesive. You can PM me for applicators and contact details.
