My dwellings brickwork (on slab) has two rows of brick below the DPC.
How low can you go to lay concrete paving? Can it be installed so the paving surface level Is just above the slab? Thanks.
Browse Forums Paving & Concreting Re: Concrete paving against brickwork 2Mar 17, 2019 8:49 am Regulations are applicable to the distance between the finished surface level and the DPC. Various sub regulations exist applicable to the area's ARI and whether the finished surface is in an open area, a 'covered' area or an enclosed area. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5230 6 4388 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5764 |
