Browse Forums Paving & Concreting 1 Sep 14, 2008 9:29 am Hi everyone,
Just a question on a quote we got for concreting our shed slab. Its 9x4.2 and the quote is $5000.00 for coloured concrete with a pump. Uncoloured is $600.00 less. Apparently this guy is very good and has done work for a few of the neighbours, so we have seen his work. Is this OK? Paula Re: Quote for shed slab 2Sep 14, 2008 6:05 pm all depends on the slab construction is it an engineered slab ie : raft, pod etc?
if so then not a bad price assuming all plans and site survey are already done. if it is standard 100mm thick with sl62 etc with a pump, (a standard slab that size doesnt need a pump unless there are access problems) then a bit much but without seeing the job, build specs, amount of excavation etc its hard to tell reinforcement has gone up around 70% in the last 6 odd mnths and concrete has gone up as well so concrete jobs arent as cheap as they use to be Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Quote for shed slab 3Sep 14, 2008 6:22 pm Thanks Davinci,
It will be poured after the shed has been erected, the pump is because of access issues. No excavation, or raft or pod??(I think) Not sure of the thickness - dont think to ask those questions - DH will know! Paula Re: Quote for shed slab 5Oct 27, 2008 9:46 pm 7k without pump or colour
Just had my mate over and he runs his own concreting business. He says that is a rough price because he isn't sure of Melbourne prices Re: Quote for shed slab 6Mar 11, 2009 6:41 pm is it better to put the concrete in after the shed is up or before?
-Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Quote for shed slab 7Mar 11, 2009 6:50 pm my parents paid around $8000 for a 12x18 only a couple of weeks go not coloured and it was a h soil finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Quote for shed slab 8Mar 11, 2009 10:40 pm is that metre's or feet? 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Quote for shed slab 9Mar 12, 2009 11:31 am most steel supliers warranty wont cover the steel sheeting if concrete is poured against sheets so in regards to warranty it is better to pour pre construction but keep in mind dyna bolts will crack the edges when installed to close to outter edge of conc. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Quote for shed slab 10Mar 12, 2009 11:28 pm davinci so in regards to warranty it is better to pour pre construction mmm i am going to have to look into that, even if you brace the walls at the base of the shed before you pour (like your would normally) it would seal up the shed from water rats/mice getting in. -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 673 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5416 |
