Browse Forums Paving & Concreting 1 Sep 03, 2008 12:34 pm I want to have a small brick fence running up the side of my driveway. My drive slopes up to the house.
My question is in respect to the concrete footing for the brick fence. Do I create the footing: 1) so that it slopes up; or 2) so that it steps up? Thanks in advance. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7384 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10364 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3436 |
