Browse Forums Paving & Concreting 1 Mar 01, 2018 1:03 pm Hi, I've got my driveway that is about 18 months old, some of the areas where it gets a bit of rain. Some of the sand has come out of the joints. Only the edges were mortared in and the rest is sand. What is the right product to use for re-filling the gaps? I have seen this geofix product which you can just sweep and leave but it says it needs a minimum of 25mm gap? https://centenarylandscaping.com.au/sho ... rs/geo-fix Re: gaps in driveway 2Mar 17, 2018 6:58 pm Try a gel set paving grout. In WA we have paveset or pavelock . Speak to your local paving suppliers and they should be able to point you in the right direction. Regards Shaun Re: gaps in driveway 3Apr 24, 2018 10:53 am Thanks @Lakeside Paving - I have bought Sika® Pave Fix Plus - I assume it's similar. Going to use it on the weekend. Thanks for getting back to me. Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7450 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19134 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 7007 |
