Browse Forums Paving & Concreting 1 Sep 03, 2017 11:32 pm Hi have recently got a concrete path done around my house on the garage side. Compliance wise it sits >7.5cm below seep holes but the slope doesnt really appear to slope away from the house. It slopes more downwards per the block of lands natural slope. I'm wondering if this is fine from a drainage standpoint and it appears if it were to rain that it would drain downwards towards the driveway? Is this considered compliant with the 1:20 sloping required? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Concrete path around house query 2Mar 07, 2018 9:33 am Sarahxox Hi have recently got a concrete path done around my house on the garage side. Compliance wise it sits >7.5cm below seep holes but the slope doesnt really appear to slope away from the house. It slopes more downwards per the block of lands natural slope. I'm wondering if this is fine from a drainage standpoint and it appears if it were to rain that it would drain downwards towards the driveway? Is this considered compliant with the 1:20 sloping required? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you didn't already I would get a building surveyor to report on this to check compliance. As long as surface water is being directed away from the house (albeit, in a downward/back direction not outward) then you should be ok from a performance perspective. How is the concrete performing now? Any pooling etc? Just my two cents. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12873 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8467 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6535 |
