Browse Forums Paving & Concreting 1 Jul 10, 2017 4:37 pm Have been quoted just under 10k for approx 94m2 of concrete plus stormwater as per the below viewtopic.php?f=1&t=88570 - didnt realise their was a dedicated concrete section when i posted this They will use f62 mesh and 100mm thick concrete throughout the estate specs are 150mm thickness for driveway but the engineers footings report indicates due to soil type (H2-D) the driveway should be a minimum of 120mm thick with a sl72 reinforcement my question is should i be going back to the concreter's that have quoted and getting them to spec it as per engineers report Will be doing a 7x3 meter concrete slab in the back of house to allow for a future pergola - expecting to size it up to extend just beyond the concrete so that its posts don't need to impact it unless i get advise to delay concrete till after pergola is erected - though i assume would be far easier to concrete the back of the house when doing the paths and driveway Re: Driveway thickness question 2Jul 10, 2017 6:53 pm You never know when a truck may back down a driveway so a thicker construction is recommended. . . . especially if you are planning more construction work. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Driveway thickness question 3Jul 10, 2017 11:03 pm Short answer is yes if you have engineering specification then follow it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Driveway thickness question 4Jul 11, 2017 11:03 am that's what i have been thinking. better to spend extra now than have to replace it in a couple of years. wondering if the reason the estate states 150mm thick is due to the soil type as well. note: If i ever build again ill pay attention to any estate driveway thickness requirements as it may give an indication of the soil type Re: Driveway thickness question 5Jul 24, 2017 11:53 pm For a driveway I would always recommend SL72 and 150mm thick as a minimum, save the SL62 and 100mm for the garden shed. Pouring your patio slab before or after the driveway or path would be irrelevant as there would more than likely be a joint between the patio slab and driveway anyway to control shrinkage cracking. Re: Driveway thickness question 6Jul 25, 2017 12:19 am thinking ill hold of the patio concrete and they can just come back when im ready to do it and i assuem use a concrete pump to get it the 24meters + to the back of the house. or just put paving down for that location. though have been thinking of doing it for the paths as well lately a good choice would be to pay for relocation , because as kvazer said it depends on your council regulations. is a great place if you're looking to do that. 2 3555 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 7407 |
