Browse Forums Paving & Concreting 1 Mar 14, 2017 1:02 pm Couple of things, Best way to make screed? I assume a 4:1 sand/cement is fine? Second thing, I hate hand mixing... Would say bunnings do a premix bag of what I could use for a screed base? Thirdly, if the above is an option, I assume it'd not the cheapest?! Just trying to get out of hand mixing it... Hurts my back! Ha ha Levelling compound also works well for this, you can feather it and it doesn’t self level at this low thickness , you can build up in layers if need be. 2 5686 Thanks for the reply. Had a look at the suggested lot and found other problem on easement, which i will asked in separate thread. 2 16629 Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4266 |
