Browse Forums Paving & Concreting 1 Jan 25, 2017 10:40 am I have a renovation project (new basement), and I need to concrete a couple of sloped walls. I have dug out to a slope of 4:1, so it's not quite vertical, but pretty steep. I need to lay a 100mm slab on the wall, with reo mesh in it. Can I mix up some 'thick' concrete and trowel the wall up without formwork, or do I need to put up sheets of formply and pour the wall with a standard concrete mix? I know I could get it sprayed, but I'm planning to do as much as possible myself. A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223632 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24873 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 1776 |
